pinion yoke strap bolts
obijuan
San Antonio TX
ok so pirate 14 bolt bible says that
[FONT=Arial, Helvetica, sans-serif]Pinion Yoke U-joint Strap Bolts
[/FONT][FONT=Arial, Helvetica, sans-serif]7/16 " head, 1.296" x 5/16-NF24[/FONT]
is the right thread pattern, but the ones i pulled out of my 87 14 bolt dont go in. did they switch to metric sometime around? if the 87s ones dont fit i am assuming that i have an older yoke with the 5/16 thread.
hope im not going crazy....:crazy:
I had problems with mine being a little rusted/mudded. I ran a tap through them and ran the bolts through a dye. 5/16--24 is what I used. Worked great. Axle is from 85 though.
