If you don't have a vortec specific block, you'll need to seal a gasket to the block, then seal that plastic cover to it. They changed the boss on the front of the block when they went to the plastic cover and it barely touches in a couple of spots. Been there, done that. Either that or you can run a conventional timing cover, only the back of the pan changed when they went to a 1-piece rear main seal.
