play in ring/pinion
skyblazer
Houston, TX
Anyone know how to tighten up the ring and pinion gears in a GM 12bolt rear diff??? I have it all broke down to change out bearings, seals, and brakes and I noticed there is mucho play in the ring and pinion. I believe you shim the bearing on the left side to mesh the gears closer? My manuals don't include any info on this. thanks...
That's where most of us rely on experienced mechs with dial indicators. They set up the gears, backlash etc. it's sort of an esoteric thing, I have seen the results when folks just "eyeballed" them................boom.
"who dares wins"
I was under my truck today and I noticed that there is about 1/8 of a turn of play in the fron driveshaft. Is this normal?
90K5
Are you sure it's the R&P? The only way to tell, is to hold the pinion still and move the ring gear up and down. You will obviously have to have the diff cover off to do this. Dont rely on moving the Pinion yoke and waiting for axle movement. Backlash should run .008" Hope that made things clearer.
<font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
