When I got my 91 K5 earlier this year, it came with a 4" shackle flip with stock springs in the rear, ORD 4" spring lift in front, and both front and rears also had a 1" block, for a total of 5" of lift. It has 315-70/17 tires on it that are due to be replaced. It had a worn steering stabilizer and a front swaybar (with disconnect). The previous owner removed the quad shocks and was only running the long one. Shocks look to be very old. The steering was all over the place and downright dangerous...
When I got it up on my lift, it had the notorious frame crack behind the steering box, so I spend the next several weekends replacing the entire steering system, as follows with new:
Trying to figure out where to start since everything I have read about people who have done the crossover kit, say that it was a huge difference, on and offroad, compared to the old design. The truck is so loose that I would not even consider taking it on the highway.
Here's what I am contemplating and am wondering what you all think I should do first:
There is a lot of body roll when you are parked and steer left and right, if that means anything. It looks like the front spring shackles are twisting quite a bit.
Anyway, I know this is a long post, but I don't want the throw good money at bad, or buy the same size tires if the answer is to bring the overall height down. I know several people that have had K5s with 35s and had nice tight steering, so I know something is off.
This is my third 88-91 K5, so I'm not new to the trucks, but the last two I had on 32s with no lift, so hard to compare.
Thanks in advance
- PSC Steering gear
- ORD weld on and bolt on frame brace, after welding up the cracks
- ORD crossover steering kit
- Heavy duty ORD ball joints
- ORD Tie Rod and heavy duty tie rod ends
- All wheel and spindle bearings
- Rotors and pads
- Borgeson U-joint at the steering box and steering column, with new steering shaft
- Steering column lower bearing
- Removed the blocks to drop the overall lift 1"
- All new shocks and either replace the current shock position, which is apparently not the one it is supposed to be in if you are using only one, or replace the full quad shocks
- Drop the lift down to 2-1/2 and reduce the tires to 33" just to get it lower to the ground? ORD custom springs front and rear.
- Get the kit to reinstall the steering stabilizer (the ORD crossover kit said that it's not necessary, but I'm wondering if putting one back on would make a difference
- Same as above with the sway bar
- Get new tires (what is on there now are very worn and uneven), but I don't want to buy the same size if the overall lift is greatly contributing to the problem
Thanks in advance
