You're 100% right about that. I was holding off on new tires until I nailed down a lift and tire size. Pretty sure I'm going 33s so I should just bite the bullet and do that.I have run crossover steering on my K10 with three different sets (and brands) of leaf springs and it has done just fine, with no issues to report.
IMHO, a track bar on a leaf spring truck is just a Band-Aid, and really takes away from vertical suspension movement.
Those duratrac's look pretty worn, I bet a set of new tires will make a world of difference.
Good point. Maybe I should start with new hangers and poly bushings. That's not a ton of $$Hydro assist is cool, you don't need it. Panhard bar with leafs make things bind. Leafs go up and down, panhard goes side to side when suspension cycles. If the leaves are letting the axle move side to side then the bushings are all worn out.
It looks like the steering wheel alignment is just that the steering shaft (with 30 spline Borgeson coupler) just need to be reclocked to the correct center, or at least that is the working theory. Right now the steering wheel is off just about exactly 90 degrees to the right. That's an interesting theory on the drag link. It's what ORD sent me based on my 4" of lift. It's hard to describe exactly, but the responsiveness is just nowhere near any other K5 I've had or driven. My other ones respond like a Porsche compared to this one.I went back and re-read your 1st post.
And now I happen to remember that you need to have the steering box centered to have it be in the tighter portion of the worm gear to rack mesh.
So how far off of center is the steering wheel?
Is it only the steering wheel that's off and the column is straight? (Difficult, but not impossible)
Is the drag link little bit too long and not allowing enough adjustment to get the steering wheel centered?
You will get some movement at the front shackles and more when there is more resistance to turning, like when stopped on pavement. I honestly can't give you a measurement to expect as normal.
Yes, they do drive a little like a boat, even though the body roll is opposite of how i remember a boat behaving. However, that doesn't mean that there isn't a problem with your truck, you just haven't found it yet.
