harley011905
Newbie
I have a 1978 k10 with 350 and 350 trans. I replaced the starter switch and now it won’t start. They key is now locked in the ignition it will turn to crank but it won’t come out. I tried the trick with the ignition switch and screwdriver and it turns on the power but will not crank. This is my only vehicle. Please point me in the direction of fixing this. Do I need a whole new column now or do I need to bypass if ion and put it on a switch? Again please help. Thank you!!
