Thanks for the advice,I see no signs of a name or model number plate on the plow ,so I was guessing at what make it was...its the beefiest blade and push frame I've ever seen on a plow only 7.5 feet,its built like a 10 footer for a ten wheeler!..it has a nice snow foil and the :"ears" where you pin it on do look different than the Fishers,instead of three holes one right above the other,this plow has a triangle shaped ear and the 3 holes are offset ,not in a staright line...its got a 25" spread between the pins so it'll go right on the Fisher push frame--however,my '82 K2500 has a home built lower push frame someone made by boxing the front frame rails in with 3/8" plate and they used a Fisher push bar with a 22" spread on the a-frame pins,so unfortunately I cant swap blades between the two trucks without making some kind of adapter...this Diaond blade is a BEAST,I bet it weighs a good 150-200 lbs more than my Fisher blade...its like new too,I got a great deal when I traded an old Sears tractor I had paid 40 bucks for it,all I had to do to the tractor was clean the carb & gas tank and do some tinkering!...wish I could get more deals like that...gotta love Craigslist's "barter" section!...
