I've never seen a plug wire arch from the plug boot, but my 2001 s10 is doing this. #5 is arching from the spark plug boot to the manifold heat shield. What could be causing this? The plugs and wires are 45,000 miles old. Oddly enough, this only happens (to my knowledge) at idle or just off idle. It stumbles around 700rpm but never does it again.
Second question. My battery tests at 12.5v. With the engine hot and running, straight off the alternator I'm only getting 13.8v. Is this cause for concern? Normally I seen 14.4v but if I can limp this alternator along to save cash, I will. The alt is from a fullsize truck, 140amp, Delco (made in mexico).
