whats the best wires to use on a big block with headers ? which boots are best, angled, straight,90 degree ? also ones that wont break the bank if you know what I mean
Any good name brand.. I personally like the hi temp wires. don’t fall for the “hi performance” hype…. standard ( 8m I think?) would be ok. Just make sure you secure them good and don’t let them burn up on the headers….that’s the important thing.
Agreed, MSDs or Taylors with some plug boots. I believe boots should be used whenever headers are present, nothing beats burning a $100 set of wires up
The straights touch the tubes, the 90* touch the flange.
The Taylor 135* must be the same as the Accell 60*. They work perfectly on all 8. I found some heat sleeves about 6" long that fit over the boots, never had a prob.
