pontiac help plugs and wires?
obijuan
San Antonio TX
where the hell are they, it soulds like ones misfiring something. its really hesitant to go, it sputters and has a rough idle. i dont know where to look for the spark plugs to check if that is in fact it. can somebody here tell me? i know its not a blazer but thats my other car. any help would be appreciated. thanks
step 1 : remove 4 bolts holding the 2.4 twin cam cover on.
step 2 : unplug wire on driverside of cover for the ignition modual.
step 3 : pull cover basicly stright up.
step 4 : plugs and cap are not cheep.
help full hints. : only use the exspencive ac delco plugs. and if the big arss white cover thingy is dirty with like black sutt. replace it. it houses the coils.
thanks to "sweetK30" i just replaced the plugs and boots on there and did everything right but it still has the same problem. wtf. its like i didint even do anything. the plugs didnt look all that bad either but were black and sooty. its hard to start and stay on, and with the pedel holding the idle up it runs ok for a second and then bad again what could this be? computer, fuel pump? im at a loss here i need this done by monday
