Carriers, gears and housings are all different almost always. That's why they all have shims.
Having said that, carriers are usually close enough that they don't require a change in shims. Always a good idea to check it, i've had to change backlash once in six or so carrier-only changes.
And not sure between bothering to swap to a posi or spool (welded diff)? I'd figure which one you really want/need first. BIG difference between the two.
