Well, my luck on this nicely built 383 ran out. Starting to have some bubbles come through the coolant bottle and now got slight white smoke at idle. I tried the blue dye and tube head gasket test after removing a good amount of coolant but the antifreeze kept coming into the test tube and could never get a good reading on the blue test fluid. Besides a compression test, any other ideas to track down which side it might be on? I'll probably do both head gaskets just to be safe. Really didn't want to tear this engine down. Will be checking cylinder head surface for warping and cracks. Also, was thinking about using this product to look for any cracks on the block / heads. Any other suggestions?
Blue test fluid and test tube:
View attachment headgasket.mp4
