Possible Trans problem?
OrangeCrushK10
Square State + Suspension Item
HA! I remembered my password!
Long time no see CK5.
So anyways, I thought I'd consult the best diagnostic group I know on this one.
I have a 1997 K1500 Yukon, 350 tbi, automatic. It starts, idles and revs fine out of gear. However, when driving it has no guts. In order to accelerate I have to just barely touch the gas, any real gas pedal use and it just sits there slowly losing speed, sometimes making a clanking noise or having a slight pulsing feeling.
I'm thinking the transmission since it has no problems out of gear with revving or starting. However slushboxes are one of the few parts on a vehicle I know very little about. My gut is telling me torque converter, but I've read it may also be the pump or even the clutch pack.
I believe the trans is a 4L60E, but I'm not positive.
What is your opinion ck5? :bow:
you may be right on the converter do you have any leaks ..... is there any gear that does it more in or just all of them ....
All the gears, except maybe 1st. It seems to get up to about 20mph just fine.
I've never noticed any stains/puddles left under it, but I checked the fluid yesterday and it was about 2qts low. I topped it off hoping that's all it was.
I'm not looking forward to swapping a torque converter in this. It's my DD too is the worst part. :doah:
2 qts low I say was your problem.
How often do you check your fluids?
If this happened over years, then you might be OK for a while, if it happened in a few months you wanna find where it went.
