DIRTY LU
awesome stories keep em coming..
was on my way to a camping trip when my '75 pickup acted like it ran out of gas, but i had just filled it up. the next day my freind and i replaced the fuel pump on the side of the road, but it still wouldnt run. so we used one of the heater hoses to siphon some fuel out of one tank and put it into the other tank (1st tank must have something in it) and it fired right up. havent used that tank since then.![]()
got stuck boggin with 39.5 MT's axles in the mud, used a 2ft piece of log and a chain wrapped around it through the wheel to "limp" out, actually worked pretty well but DO NOT attempt with anything but steel wheels
I read about this as a kid.then finally i got to put it to practice...i started my truck with a chainsaw!!! my girlfriend thot i lost my mind.we were out gettin wood and usin the wench and ran the battery down and we were high on the mountain with no way out but to walk and i remembered what i read when i was a teenager and took the blade off the saw and the belt off the alternater and connected the belt to the drive gear for the chain and spun the thing till it charged the battery enough to start the truck! my girlfriend was amazed and i was glad we didnt have to walk down the mountain.--------p.s. make sure the key is in the running position before you spin the alternater![]()
It can get expensive, but if you are in a bind you can actually weld with quarters instead of welding rods... I actually welded a leaf spring back togeather using this method and made it back to camp.
gabe
Damn that was a long night. And I had class at 8am.
We pulled the shaft out, looked at it, had a beer and picked up what was left of the needle bearings (which were then held in with RTV, race was actually ok) And took his 4 d-cell maglite, pounded it over one end of the broken shaft, the pounded the other piece of broken driveshaft into the other end of the maglite. Wrapped the piss out of the shaft halves with duct tape top keep them from walking up and down too much, slipped the shaft back in and limped off the trail. Worked great enough to get him off the trail and onto a waiting trailer
