beater_k20
Banned
sled_dog said:being as the blocks are exactly the same as the earlier Single piece rear main seal engines(except they don't have the fuel pump drive shaft hole drilled), He is inncorrect.
my Vortec not only has the boss for the pushrod, but its machined too. there's no pushrod lobe on the cam, but everything else is there.
the stock intake is a restrictive POS. hell, even leaving the heads stock and swapping the intake wouldnt be that bad of an idea. FWIW, modifying the TV cable bracket isnt that hard.
I suggested a better intake.
