Power brakes
dansblazer
Oshawa, Ontario
I have changed the axle of my blazer to a 14 bolt 9 1/2".My question is seeing that I had a 12 bolt and now the 14 bolt is the brake booster able for the rear shoes?
Dan /forums/images/graemlins/confused.gif
yes it will be fine, the wheel cylinders for bothe sets of brakes will be about the same size, youll be fine, the only problem you might run into is when you go to rear disks
