Hi everyone, I hope you can help with a problem that's just recently come about.
I had everything rebuilt/replaced from my head up (pistons & rings looked good so block stayed as is) and after the rebuild I was getting a check engine light for codes relating to O2 sensor and TPS (throttle position sensor) voltage. I replaced the O2 sensor and reset the codes, and since then I haven't had the check engine light come on.
However, I have been experiencing intermittent idling issues (surging idle sometimes) and the motor seems to "bog down" on occasion when I put the accelerator to the floor.
Do you think this is TPS related? Should I bite the bullet and buy a new one and see if that fixes the problem? FYI it's a stock '89 with factory TBI 350.
Thanks in advance for any help!
edited to add solution found!
The timing had been set with the EST wire CONNECTED, which was causing my idle to be off. I had him reset the timing with the EST wire DISCONNECTED and it has been running great for 3 years.edited to add solution found!
