Need some possible inputs. My rear window just stopped working, luckly it was in the up position. I have checked all electrical connections and everything seems fine. The motor and regulator seems fine also. I'm stumped. What I would really like to do is remove the power switch and replace everything with a manual handle, is this possible? I figure why replace everything and spend 300 dollars to possible not fix it when i can spend half of it and put in a manual handle.
