I've added hydro boost to the blazer and wanted to add a cooler but read that it need to be lower than the reservoir.
72 Blazer, one tons, 40s, no assist ram, factory style power steering pump which keeps the reservoir pretty low. If I put it in front of the radiator like a standard cooler it is significantly higher than the pump and reservoir. Anybody run a cooler behind the grill with a factory style setup and no problems with it flowing back into the reservoir and overflowing it or getting air in it?
Thanks Sean
Thanks Sean
