So Im in the middle of my crossover steering conversion. I got a PSC gear from Offroad Design. PSC recommends using power steering fluid, not atf. My old pump and lines leaked like mad anyway so I figured Id get all new everything. When you get a pump from the parts store for a K5 they give you one that has already been lubed with ATF. Do I need to flush out the ATF with power steering fluid first? Is the amount in the new pump negligible so I can just fill up the system with PSF and not worry about it?
