I have power steering issues, the usual high pitched whirling sound when i turn the wheel past 80%. funny thing is it seems to do it more when i turn left then it does when i turn right. I just need a run down on the steps i should take too get this fixed. How do you bleed PS fluid? A guy at a local shop told me too get a baster and suck out the old fluid and fill it back up and then turn the truck on and crank the wheel and then crack the "seal" on one side and to repeat the process on the other side and then to repeat as needed until i see clean fluid. What seal or rather nut do you think he is talking about? and if you do please post a pic of said nut or seal to help me locate it. id like to try as much on my own if possible but if you guys think PS issues are better left too a shop let me know. As always thanks a ton for all the help!
Here is my set up just in case
86K5 6" skyjacker lift 35"toyo MT open country, rest is stock
on you for asking questions in two threads
The bleeding process and where to crack is covered in the other thread you hijacked
With your lift, what components did you change to correct the steering? (i.e. draglink, steering arm, etc?) I suspect you'll find that the front axle turns father to one side than the other, and this is has worn the PS pump out. That and/or it may be low on fluid, and running it that way for a long time will also kill it.
At the very least, go check your fluid level, and if it's low, top the thing off right away.
If the level is good, pull some out on a rag or with a turkey baster. It should look like brake fluid, i.e. yellowish clear, and shouldn't smell burnt or be real dark. (Like if it's any darker than medium-wimpy iced tea, you're in trouble
Now, if you didn't change the steering with the lift, you're gonna need to make sure your steering is symmetrical, by the addition of a raised steering arm, and MAYBE a dropped draglink (though they're a PITA to align). Ideally of course we'd all have crossover steering, but that's expensive and complicated.
Then have the truck aligned, or at least adjust the draglink yourself so that you have the same travel left and right.
Only at that point would I say you can/should replace the pump, if it's still whining ... 'cuz otherwise you're gonna be killing pumps again and again.
Make sense?
-- A
