I’ve been busy too but I went out to that garage and checked a few things out.
So here’s what I’m working with:
The brains behind this is a Weelye RX19
The normal model is for 2 motors but this one is setup for 4wd.
During basic operation the power to motors sends 12v and around 4amps if I’m measuring correct.
But during modified operation I unplug the power to motors and connect it to a Warm 89564 winch relay switch.
18v Milwaukee power then goes thru a motor speed controller, the relay and then the motors.
I went with the warm switch because the grounds from both circuits are separate.
One problem I’m having is as soon as I connect the ground to the relay switch (center tab) it connects and starts to get warm it works for a while and then something smells like burning circuits.
I hope this clears up what I’m trying to accomplish.
After I get the bugs work out for this system I want to duplicate it to convert this into a 4wd.
