So previously my power windows on both doors were working, recently i had a short and would keep popping the curcuit braker as soon as power was turned on. I found the short and fixed it but now both windows will not move up or down. I have power through the main wire and power coming off the drivers door switch for the 4 motor wires (2 for driver side and 2 for passenger side) and the ground seems solid as the fuse is no longer popping as well as when tested with a multimeter doesnt show its coming into contact with power. So whats the best shot at fixing the issue?
