Mine has 1 large wire from battery-starter, 1 red from starter-buss(on firewall), 1 red from starter-alt(charge wire?), 1 red from starter-thru firewall connector, 1 red buss-thru firewall connector, 1 red buss-alt, 1 brown alt-thru firewall connector.
Batt->starter(red)
Starter<-alt(red)
->buss(red)
->firewall(red)
Buss->firewall(red)
->alt(red)
Alt<-firewall(brown)
My new harness has all the alternator wiring in it already as well as starter solenoid. New harness connects to battery power and also has IGN power wire that I've connected to the wire that used to power up the coil.
If that's comprehendable. Which of these wires can I eliminate and which need battery power for the fuse panel under the dash?
