badmix
First is the OnBoardAir that I decided to go with, its the CO2 tank setup. I thought about goin the ViAIR with a compressor and tank, but I wanted something simple for right now. The compressor setup is still in the works, but thatll be later on.
The CO2 gives me 150psi and I can fill my tires from 15psi to 30psi in a few seconds and I can do about 30 of them, so it gives me some longevity. I found a pretty good spot to mount the tank, Its behind the passenger seat , right beside the seatbelt mechanism. If ya have a k5 ya know where im talking about, for everyone else, jus play along. lol.
Anyways here is the bracket ( I dont have the tank, I sent it to get filled, so ill have pics of it next week, its jus a basic 10lb tank, much like Nitrous tanks, etc.) Where ive got the mount, I can put anysize tank i want and I have room on the other side to run a 2nd tank if I desire.
The 3 Black flat thingys ya see on the base of the mount are called ELEVATOR BOLTs, they are like Carriage bolts but are FLAT, work great in this type of application. I plan to put a rubber pad down on top of those anyways, metal on metal is bad, mmmkay.
I used a piece of 1/4 mild steel as reinforcement on the bottom of the truck, the floor boards and metal are pretty thin stuff. I also use big fat fender washers as well. Ive got another piece of 1/4 steel that I may put under that 3rd bolt jus for added support as well.
On to the next project.
This is the rear tire carrier that I had modified to now accept a gas can holder. The shop ran a tube bar from the back down to the horizontal piece and then some plate steel as a shelf. He made it a lil bigger than what is needed cuz I was still waiting on the gas can carrier, now that its bolted up, i can have him use a Plazma torch and cut excess.
And there ya have the latest upgrades. After all these upgrades and mods, I need to take this thing off roading (not jus on the beach). lol
