Pressure Washer Cleaner Recommendations
B
Bohemian
Guest
i bought a gas powered pressure washer and they're pretty proud of the different kinds of cleaners...
so i'm wondering if any of you all own a pressure washer and if so what have you found that's economical and works for a variety of things...
The first thing I'm going to use it for is cleaning the engine bays and underside of two 4x4 trucks that're oil leaking pigs, that are fixing to get new engines, so degreasing so i can repaint engine bays and undercoat bottom & frames of trucks is the order of the day.
After that cleaning the windows and the side of the house.
thanks in advance.
Are you wanting the kind you mix in with the pressure washer or something to spray on first and then us the pressure washer to hose it off?
Since I don't have a heated pressure washer to maximize the soaps, I just pre apply whatever I want to use and then blast it off.
I use Castrol super clean for grease and oil removal, spray it on first. Don't let it dry.
Other things I use Simple Green, sometimes diluted a little.
the stuff you mix with water and put in a small tank on the pressure washer
