Problem installing LMC HD window wiring kit
Houston_t
Registered Member
Metro Detroit Area
So here is the deal, my 87 has slow power windows but they both work so i picked up a hd wiring kit with relays from LMC while purchasing some other parts. This morning before i began the install on this kit both my windows worked as normal, but now only the drivers side works im getting nothing out of the pass side not even a relay click. And of course LMC offers no technical support, all i got out of them was recheck your wiring and if that doesn't work we will send you a new one.There has to be something im missing, i am following the instructions but something is off, like for instance how does the drivers switch control the pass window ? Im thinking when they had me cut the wires from the switch there must have been a splice down line that is no longer connected and stopping the pass side from working. Anyone have any experience with this kit or door wiring diagrams that i can look over ? Pass window no longer works from either switch but worked right before the install.
He did some petty body work on Trucks, but wiring he sucks.
