Procomp extended brake lines *SOLD*
Taylor
Elizabeth, CO
Procomp extended brake lines, new still in package part #7215 for 73-78 models. $75 shipped.
Gaffed said:
Obviously these will not fit a 89' with 10 bolts since the original post says 73-78.
Right there not going to work on an 89', they use a different size banjo bolt from the older Dana 44's.
I'm interested, but have to check my axle tomorrow. Also are these good for up to 6" lift or more? Thanks Jason
On ORD's website they say there adequate for up to a 6" lift, the line length is 23.5 so you can check if that will give you enough travel.
I'll have to check it out tomorrow. I didn't get a chance today. Thanks for the length info. Jason
