Project "8 ball" Street legal
Quackaddict
Glenn Heights, Texas
Well after 5 months she is put together and street legal. Still seems like there is an endless list of small things to do but she is a driver now. Sanded down all the surface rust spots and got ambitious so insted of white with primer spots I painted it for $20 myself. Didn't want to go rattle can so I went another route...(shall remain nameless for flaming sake.)
Gay project name but when I got done my wife said it looked like an 8 ball with the black truck and white top (waiting on $$$ for soft top) so she got me an 8 ball shifter knob and key chain.
Also I am still painting the side moldings.
before
after
ok so yes this is embarrassing. I had bought a gravity fed spray gun at a garage sale a while back and have been itching to use it. So spray paint would have cost me about $40 and I wanted to use my gun so I used rustoleum paint for metal and painted surfaces. I did some decent prep work. The pic is kinda far way so you can tell.
It covered very well and from what I can tell is very strong not goona chip or scratch very easy BUT there are several areas that didn't come out smoot and are kind of textured and some look real good. This was my first time ever with a spray gun in my hand and I was experementing with thinning the paint as well.
All in all for what it is I am very pleased, it was cheap, I did it my self and it should hold up well especially off road.
Flame away
It looks more like an old-school K-9 vehicle, back when cop cars were mostly B&W (instead of foppy colors like pastel blue and white).
well the before truck was a completly stock 80 K5. The only thing the PO did was take out the stock 305 and put a rebuilt 350 with a cam upgrade (good decision) Then it has sat for the last 3 years. (suprisingly all I did was change fluids,plugs, wires, battery, alternator, belts and starter and it has run great.
I took out the 1/2 ton 12bolt and 10bolt with 3:08 gears and put in a 3/4 ton 14bolt SF with gov bomb and a 10blt both with 4:10's. Got a set H1 wheels and tires and took the rims off and put on black rockcrawlers. Then put on a 6" RC lift and zero rate. Did the brake lines and all new fluids. I also added an Edelbrock Air-Gap intake manifold. Then shot her black and painted the trim red.
Also added the ever important "8 ball" shift knob and skull T-case shift knob. I also have a set of Triple gauges to install to track all my temps better.
Needs:
Extended driveshafts
Fix speedometer
Rear main seal for tranny.
Tranny Cooler
Wants:
Heavy front bumper with winch
Boggers or IROKS
stereo
Cowl Hood
better interior.
