Well today I got all geared up to work on this beast. So i was going to take the back axle off and move it out of the way for the frame work. When I discovered the frame is broke just under the heater box on pass side. I also noticed that most the cab is rotted from the underside. More specificaly the body mount supports. Although both can be fixed, Im thinking it will be easier to build the red k20 diesel instead. I checked it out today and the body is in crappy shape, but the cab mounts and stuff is all solid and the frame is straight and no cracks. It already has the hydro-boost just need to swap in the engine from the crew cab. Then trans x-case axles and lift from the K5. So im not sure what to do the crew cab will be ALOT more work than i first thought. I may just build the red k20 for now and work on the crew till its done then swap it all back or just ghetto-fab the crew cab onto the k20 frame later. Tell me what ya think.
Balzer
