Well It wasn't raining today so I went out there and worked on it again...
I got both the seats out, the front seat belts, the carpet, the insulation, the x-case plastic cover, and some other small thing... here are some pics;
How do I go about getting that x-case thingy out? Not the shifter but the little tray thing? I tried pulling it up after I took the bolts off and couldn't get it out, just pulled up about an inch. any ideas?
As you can see in one of the pictures I found more rust!! a bunch of rust on the drivers side floor... and about 3 holes the size of a small plum...
Also as you can see, my tranny/x-case floor hump is bolted there, so I can take it off... one question, if all the bolts are out, would I just beable to pry it up? there is a bunch of sealant around the edges, but is it fastened anywhere else? I tried getting it up with a screwdriver and it wouldn't move, it just bent the humps edges a bit.
ONE more thing to say... as you can see in one of the pictures, the rear bumper is just hanging there by one bolt... THAT WONT COME OUT /forums/images/graemlins/mad.gif
Thanks for reading, and keep checking back as the days go by for more progress /forums/images/graemlins/peace.gif I had to head in because of thunder /forums/images/graemlins/mad.gif /forums/images/graemlins/doah.gif
