dfl701
How is it so big with only 5 inches of lift
Why do you call it a K1. My current theory is because of the 1 ton drivetrain but numerically it doesn't make sense. K10 to K30 vs. K5 to K1.
Also, that drivetrain rocks. I am officially jealous.hey roman, when you're ready to lower the ride height, i'll come over and help you remove the sway bar.
i'll bring a foklift too, to help load the fat chicks in.![]()
OK, I'll bite.Why do you call it a K1. My current theory is because of the 1 ton drivetrain but numerically it doesn't make sense. K10 to K30 vs. K5 to K1.
So you have portal axles and the works? Sounds pretty swee
Edit nevermind just went back you have the diesel LOL
It's a k chassis with an H-1 drivetrain, I don't know HK, KMMWV, KH, H5! K-1 just fit the best I think.. I guess not![]()
.Now it makes sense. How 'bout K-H1. I like the H5 too. I am guessing the name Kummer is out.
Well it is technicaly a GMC Jimmy!!
I need to ask what brand and kit number are the poly cab bushings?
They don't look right from where I see at the radiator support. They look like the '81'-91 mounts where the '73-'80 mounts are different. Maybe I'm wrong or maybe you don't have the right mounts.
You hummered your jimmy???
maybe I should call it project Hedgehog!
