I am in love with this Suburban. A (clean) 8.1 swap and an NV4500/NP241, what more could you want?
Martin
Martin
4) Because of the radiator debacle above I threw the little 5.7L radiator in it just to be able to run it on the car trailer to get over to the exhaust shop but it will not run more than 10 minutes or so and gets hotter than hell. I am fairly certain that issue is a rag I stuck in the old radiator when I pulled it out to keep it from leaking on the floor. I guess I forgot to pull it out when I decided to reuse it.
Martin
I second that!Larry, you are truly an artist. [emoji144]
Thanks guys! Not sure about being an artist but more of anal![]()
), did a IAC relearn and reset the fuel trims to accommodate the new injectors she runs a lot better…..and that hot rod lope went away which I am so glad
. It still has some little fine ECM tuning to do as runs a bit fuzzy in cold start open loop but other than that, she runs like a scalded dog at wide open throttle. The RayLar cam definitely gave it a lot more top end although at the expense of a little low end grunt loss but I’ll know for sure once the tuning is all dialed in. So far, I’m really happy the way it turned out and it will only get better once the ECM tuning is finalized. It’s pretty funny how such a big truck can flat out scream when you poke it in the neck burnout
Glad to hear it's coming together!
But still got a ways to go. Looks fantastic, bet it rips!
This is kind of off topic but your laptop mount made me wonder this. What map and tracking software do you use on the road?
So other than some tuning left to do. Impressions of the raylar cam?
Worth the coin?
Beautiful job!![]()
I may have missed it but what are those wheels you are running? I really like the black and brushed rim look with the black fender flares.
They sure beat the hell out of the egg shaped black steelies that made the truck wobble and shake down the road
Great builds on both of these trucks! I stole some of your ideas to do my 1 ton Burb build.
Im seriously thinking about putting some fender flares on mine.
