Skin it...go ahead, skin that Smoke Wagon and see what happens!
you gunna do something or just stand there and bleed?
Easier to do without the t-case hanging off the trans for coming out and going in.
But it really depends on what you are using to do the heavy lifting. A floor transmission jack? Regular floor jack? Cherry picker through the door and the trans hump removed?
I may have done something similar, minus the tumble onto the creeper part..
As long as you you got it done, good deal!
I might know a guy...Anyone know where I can find a picture of the linkage set up for the mechanical clutch? Trying to figure out where to run the springs and such. Then I’m putting the tranny in. View attachment 329183
I stuck it in that oblong hole in the frame
Might not be where it should go, but that's where it was when I got the truck in 96
