BranndonC
3/4 ton status
It's on EBAY now
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=300228092811
Please share the link with all your wheeling friends so I can get her sold!
Well, due to our dog needing surgery, I need to sell Project Torque. I have owned the truck since it was basically stock in 2004.
The website Project Torque (check it out for videos) will be included for $250. If you don't want it, there is a video game company that does. If you see the file here you can see it gets tons of traffic for a 4x4 truck's site.
This is a 1973 (NO SMOG in CA) GMC Jimmy with a 514cid big block cadillac engine, 2 transfer cases, 37 inch tires, bead locks, 6 inch lift and more!
The truck is not pretty to the non 4x4er, but it works well. Here are all the specs, then I will list the negatives below.
Asking $5000 OBO (Lowered from 7k)
Here is my build video http://video.google.com/videoplay?docid=-846436932352988487
Specs
See the complete build pictures, and videos here.
The Bad:
The steering is somewhat loose, it just needs new steering stabilizers I think.
The paint on the hood is chipping
The dash works but is ugly
Needs a rear shock and small frame weld
Transmission to doubler mount leaks
Parking gear only works on flat ground (cheap fix)
I want $10k for it, but I know I will never get that back, so I asking for about 1/2 which I know I can get. I will only ship if buyer arranges everything, but you probably want to see the truck in person first.
Truck is located in Santa Ana, Ca (Zip 92707)
Truck Videos
http://video.google.com/videoplay?docid=5212342541814172295
Racing Friends
http://video.google.com/videoplay?docid=6316523331978730287
Off Roading in Cooks Corner
http://video.google.com/videoplay?docid=-140638331742455668
Friend Getting Soaked
http://video.google.com/videoplay?docid=7497658226736741754
Off Roading at OCX Off road
http://video.google.com/videoplay?docid=2393992480604363874
Off Roading at Silverado Canyon
http://video.google.com/videoplay?docid=194155633634704245
7 Burn outs
YouTube - Lifting the front tires on my 4x4 GMC Jimmy
Wheelie
Specs
- 1973 GMC Jimmy ($1500)
- Engine ($2500)
- 1976 Cadillac 500ci Bored .060 over. Now 514 Cubic Inches 8.3 Liters. Fully Balanced.
- Pistons - 4.364 inch 8.5:1 Keith black hypereutectic flat top pistons
- Crank - Stock .020 grind 4.3 stroke
- Heads - Stock 120cc with three angle valve job. Street/Strip valve springs
- Timing chain - Stock
- Cam - Duration @ .050 range 220-228 Valve lift range .525"-.538" Estimated power - 350 HP 525 TQ
- Transmission ($500) - TH400 (2.48, 1.48, 1.0). Out of a 1984 K30. Fresh rebuild & Shift Kit. New TCI 13” Torque Converter
- Transfer Case 1 ($0)- NP203 (2.01 low, 1.0 high) Out of a 1973 GMC Jimmy
- Transfer Case 2 - NP205 ($0) (1.96 low, 1.0 high) Out of a 1984 1 Ton Chevy
- Dual Transfer Case Kit from NWF ($1000 I think)
- Suspension Front ($500)- 4 inch Tuff country EZ ride springs from Off Road Design , Zero rate
- Suspension Rear - ($250) Off Road Design shackle flip and stock springs, Zero rate
- Body lift - ($75?)1 inch aluminum pucks
- Axle Front - ($2000) Dana 60 (Out of a 1984 1 Ton Chevy) with 5.13 gears and Powertrax locker
- Axle Rear - ($700) 14FF (Out of a 1984 1 Ton Chevy) with 5.13 gears, Powertrax locker and 1976 Cadddy Eldorado Calipers
- Tires - ($1000) 5 x 37 inch tall 12.5 inch wide Interco SSR Series Super Swamper Radial / TSL
- Rims - 5 Custom StazWorks Bead locks 16.5 x 9.75 on 4 1/2 inch back spacing ($2000)
- Electric Fans - ($100) Dual fans from a 1998 Windstar
- Front Shock Mounts - ($20) 2002 f250 Super Duty shock mounts
- Rear Shock Mounts - ($15) Custom inboard shock mount (removed but included)
- Batteries - ($200) Purchased May 2007 Optima yellow top
- Drive Shafts - Highangledrivelines ($650)
- 1410 yolk on 14FF
Custom dash - Not done yet ($50) - Paint Job - Home Depot Special ($does it matter?)
- Wiring - Painless Harness ($100)
- Steering wheel - Grant ($0
The Bad:
Truck Videos
Racing Friends
7 Burn outs
Wheelie
