How many of you guys run propane on your trucks..? Especially on anything other than a stock motor..
. Bottom line is you won't regret it. I am set up with a impco 425 mixer and a model E vaporizer.This has worked well for me over the last 20 years running a variety of SBC's.Some standard setup points for a straight propane engine:
Compression: up to 10.5:1 (depends on the application and heads ie alloy heads vs iron and trail truck vs heavy hauler)
Timing: 10 deg at crank, Full adv by 2250 - 2500, If you tow max total adv should not exceed 30 deg.
Ignition: GM HEI considered a minimum standard, good leads and plugs also required.
Plugs: at range colder, maybe 2 depending on where and how you drive
Heat: Get rid of any heat risers etc that transfer heat to the fuel, LPG is gas and does not need it. This is a big thing, cool the intake charge and you will see a good change in power and economy.
Intake: Any single plane manifold with raised runners will give good service. It will idle like petrol factory manifold and run to what ever RPM you want. The raised runners help reduce intake charge temps.
Heads and Valves: Hardend seats and a good valve job, concentric seats, 45 deg face angles, no interference angle. Valve seats between 1/16 - 3/32 depending on the application
Rings and pistons: Whatever pistons you want for your application and if you want chrome rings break them in on petrol for a 1000 miles first otherwise it will take anywhere up to 60K to bed them on propane.
Cam: whatever suits you application really, you can get LPG specific cams here but they cost $$$ and the gains are almost negligible.
Only things I don't like about propane are the range limitations and the smell.
Its kind of a pain when one or two guys hold up the whole group for a bit cause they station they thought carried propane doesn't. Or when you have to run out of the trail to go get a tank filled for someone who ran out.
Those problems can be avoided though.
, and hate it when I have have to wait on people. But it is an easy fix - plan, plan, plan
!I know this has been asked before, but for the sake of answers from the guys that have recently added propane......... What kit did you use, and what kind of cost?
I would love to go propane, but for the limitations on filling up... I wont.
Same reason I really hesitate doing anything more the my motor. I want to be able to run pump gas all the time and not have to worry. Mid grade at most. Some places we wheel... you cant get anything but 87 octane.
. I never ran it personally, but it seems it would solve the problem. I just run a 25 gal tank mounted on the bed, lasts me some time about two days of hard wheeling. But I will agree, its always on my mind b/c the fuel gauge is mounted on the tank and isn't very accurate.
