I think ORD just uses the standard TREs. If so, as discussed above, you would just not ream it out quite as large. Best bet is to talk to Stephen and make sure. Honestly, I don't see how anyone is running these things (the SL or other big drop pitmans) with less than 6" of lift AND MUCH bigger bumps than the normal/common large 4+" bumps many use with lifts. My DLE still needs the smashed zirc removed, and I'll probably put a plug in after it's greased simply because ever THIS pitman *might* allow it to be tagged on a really hard stuff of the drivers side...
Also, to restate, IMO, if you run a straight drag link, you should not run TREs. On a bend drag link like ORD sells to work around the FUBAR stock cross member, the TREs are flat, so the small amount of miss-alignment is ok. But if you like a straight drag link as I do, I strongly suggest using DLEs in spite of a few who say their's work with TREs. If you get much droop on the passenger front, especially like those who have 52s or custom packs are getting, the a TRE is likely to get mangled...
