I have had lots of experience running in deep water. Most of these lessons were learned the hard way( I even lost my pants one night, but thats another story). Here a few free pointers ( remember you get what you pay for
1. plan on re-packing your front wheel bearings, if any water gets in, it will toast your wheel bearings in short order. ( there is nothing more fun than torching a frozen bearing off your spindle). Check the rest of your fluids for water after your done.
2. make sure your vent tubes for your axle, t-case, etc are located as high as possible.
3. make sure your air intake is not pulling from your grill. Water won't compress like air and can cause catastrophic failure if you ingest to much. Point your air intake toward the fire wall if possible.
4. don't drive to fast. speed will not get you through any faster, it just creates a spray of water that will get in places you don't want it.
5. If you playing in deep puddles, a little silicon around the dist. cap will help keep it dry.
6. Hook your recovery strap up to the rear of K5, and put the excess in the back of your truck before you get stuck. ( mud hole diving to hook up a recovery strap sucks)
7. Have a ball and get really dirty
<font color=red>
Elkboy</font color=red>
