pto units ofr 203 and 205 with braden pto winch
sweetk30
Back to play nice .
in the back of your brain
( sold ) i got a pto from a 203 tcase. front output now. but can be fliped for rear output. 100 shipped.
i got a pto from a 205 tcase. rear output only. 100 shipped.
( sold ) got a small drive shaft from the 205 unit with yokes prob need joints. 50 shipped as its long.
(sold ) got a braden winch setup for left side input from behind from old dodge powerwagon ram charger. 250 . ? on shipping this its heavy. but i will work with ya. and needs some work. i never tested it.
edit : lets deal i need this stuff gone asap.
what does the PTO look like for the 205..does it have a handle that comes thru the floor to engage/disengage PTO? possibly interested!
pic post
#1 & #2 = 205 rear shift and output.
#3 & #4 = 203 cable shifted unit and swap to front or rear output.
Will that 203 pto bolt on to a 465?? Will any pto bolt on any pto cover plate? School me on PTO's.....Am wanting one for a winch..:D
each there own gear setup. bolt pattern is the same tho. so you need one for a 465. then make sure its front or rear output for were you intend to have the winch mounted.
there is also a basic power level the pto can do . so dont get a light weight one and drive a masive winch with it. or it could fail.
PTO's
So which pto do you have?? I need rear output........I have one that bolts up to a 465, but case is cracked.....Maybe you have a good case? The one I have has a lever to shift for foward and reverse. LET ME KNOW
what pto do i have ?
like the ad says. a 203 tcase one and a 205 one.
the 205 unit is rear output
the 203 unit is front output.
