Alright, I'm half way done with my "secret" upgrade. It's time to share.
Before:
Mostly done:
After almost of year of searching, I have found a brake upgrade for the chevy six lug front axle. The punch line- it adapts Hummer H3 four piston calipers and rotors in a disk over hub arrangement.
The brackets and idea came from Thorparts.com, he's using a GM 10 bolt front and machining the brackets and hubs to integrate the ABS brake system to a solid axle conversion.
Take your hub assemblies apart, cut the outer hub down to 7 inches, drill the lug holes to fit 02 chevy 4x4 lug studs, and basically bolt it up. Also gives me the larger 14x1.5 lug studs.
The H3 uses a larger center hub so it slips right over, only the flange outer diameter needs cut down to fit the disks on. My local parts store did it on a brake lathe, easy and quick.
My eventual goal is to swap in a complete rear axle from a 99-06 Silverado, giving me matching rear disks and a parking brake, with matching 14x1.5 lugs.
Before:
Mostly done:
