putting fluid in a engine hoist
Depends on the hydraulic unit. Some are non-refillable. The one on mine has a filler hole towards the bottom.
If yours is refillable, you have to compressor the cylinder (to get all the air out) then filler up.
i found this old brass can with a finger trigger and straightskinny metal spout(straw) that comes out away from it at 90 degrees
it is for some kind of oil but i use it for hoist cylinder filling, it works good, its not real big it only holds around 6 oz, but its just right
find something like that at a yard sale or auction or soemwhere :D
if i had a digicam id show you this one
like this one prolly...
i use one for oiling cylinders on compression tests on the boats.... handy little item...
look closer...
Both of my engine crane's hydraulic cylinders have a small rubber plug that looks like a button about 1/2 way up the cylinder..you pry it out and add the oil there...it was missing on one of them,someone put black electrical tape over the hole!..I tapped it to 1/8 " pipe and put a pipe plug in it...I used an nearly empty 90W gear oil bottle and the pointy spout to fill mine up--figured a little 90W wont hurt it,and it does seem to pump up faster and leak less with it in there... :crazy:
