I was surprised to read they even had some Dodge vehicles using Rochester 2 bbl carbs in 1971 when Carter had a strike!--we had a '71 Dodge Dart at the junkyard that had one factory,and my co-worker never believed me when I told him that--till I found it in writing in a book I got from the library..
I have a Holley Economaster on my van's '73 307 ,it is identical to a Carter carb Mopar would have used in the early to mid 70's--it was a bolt on swap for the Rochester "small venturi" 2 bbl that was on it--everything plugged right in--choke linkage,throttle cable,etc..
I found it at a swap meet in CT ,paid $5 for it,was still in the box,guy said it was on his aunt's 318 in a Dodge for only a few months ,when the torsion bar mounts rotted off the undercarriage...thing still works great,despite me letting the van sit since 2003,I only start it once every blue moon,but run it out of gas every time to avoid ethanol damage..(I use a small lawn mower gas tank hooked to the fuel pump)..
I have seen a few Dodge based motor homes with Q-jets,but I'm not sure if they were just swapped on by the owner after the Carter Thermoquad melted (they had phenolic resin float bowls that could melt if they got hot enough!)--maybe not factory?..I recall hearing some Fords used them too,but wasn't aware of the 428 CJ using them..
I have seen a few factory Q-jets on 1966-69 Pontiac straight 6's with the OHC too--proof they'll work on just about any size engine..
I would have put one on my 250 six instead of an Edelbrock if I had a Q-jet still hanging around..
