1TUNK5
Registered Member
im swapping in a 14 bolt dually and was curious about wheel spacers, anyone have experianced this? what was the fix? or is it best to find someone looking for the dually hubs to trade for the single ones?? thanks
Holy crap! That will make the wheel stance very, very narrow.Leave em and run h1 beadlocks![]()
Holy crap! That will make the wheel stance very, very narrow.![]()
Not dually bearing hubs. They go inward more than the SRW hubs.i thought the dually hubs set the h1's out a good ways.
i thought the dually hubs set the h1's out?
Arent they 4 inches wider? So that takes the 7 inch backspacing on the h1 wheels down to a 3 inch backspace, wich is perfect....
i have a drw c&c 14ff in my truck. put on 2" thick per side spacers fit no problems . now its the same as a srw axle for width.
lot faster and cheeper than swaping around parts. and if i want drw again unbolt the rear and bam drw. front swap hub/rotors and drw.![]()
c&c 14 ff rear is factory narrow rear. unless you build your own.
