Question for Ryoken
max 02
Roll the dice…
Eckville Alberta Canada
I got a gallon of Tremclad it says on the can to reduce with mineral spirits...I was wondering how much for the gallon?
I might be doing a little rolling and tipping.:D
most reductions are in the 10 to 15% range... but with any material, proper viscosity for how your applying is what matters.. poorman's viscosity test, pull the paint stick after mixing, stops dripping in 4 or 5 count, thin.. 8, 9 count, thick...
if your rolling and tipping, you'll want the paint pretty thin, with multiple coats..
Thanks Paul!
I Think I might have a few more questions for ya later.
Like can you remember the link for when you talked about rolling and tipping...I can't seem to find it.
it was a thread about an orange 69 charger.. it was more me trashing the technique than a few tidbits of tech later in the thread...
I've rolled and tipped many a boot stripe in the marina's... being it's mineral spirits, you can get decent results as it's a slow reducer.. which is what you want for rolling/tipping, a reducer that levels out...
patience is key.. you cannot expect to get full coverage in a coat or too... too heavy will result in runs and/or brush strokes..
scuff between coats... more thorough sanding in the later coats.. i've always found you usually need to do 5 or 6 coats to get decent results depending on color/coverage.. it can be WAY time consuming...
you'll also want to be a 4 drip on a viscosity test.. you can foam brush uncatalyzed paint with good results.. catalyzed a quality bristle brush is the way to go...
Sooo much reading in that guys thread.
On another note...... It does look damm good for rolling paint on in some cases :popcorn:
But my brain hurts now... Time for a BEER, ah I think I could get used to this being 21 thing hahahaha:haha::haha::haha:
the amount of sanding hrs in a job like that is ridiculous.....
I'm lucky that way we got air compressers all over the farm.
Just bead to find a place the isn't to dusty to paint.
I could use my garage but it gets alot of traffic through it during the day,my neibour wants to build a spray booth but I'm sure that will take him eons to finish.
Just do a makeshift one with some plastic, sweep and wet the floor down before painting so little dust gets in the air from you moving around, get some lights, u could get fancy with some fans, some furnace filters and some duct tape too :waytogo:
No.. I think I got a new plan, I know some guys...:D
Let me know if you find one that you also dont need a compressor to run! :doah:
back in my 20's, I rented a compressor for the day on many an occasion to paint a vehicle..
the Power Wagon..... start to finish in 3 days in a dirt driveway....
Yeah money and time...:whistle:
My new plan is,the Hutterite Colony just down the road from me paints semi trucks in there wash bay,I think I can get one of the boys to splash some paint on for cheep.
We`ll see.
