- Joined
- Mar 3, 2000
- Posts
- 9,124
- Reaction score
- 7,079
The plate for my 203/205 doubler is stripped on the bolt holes that connect to the cross member. Got any good ideas on how to fix or repair???
No faith in ye olde helicoil?The plate for my 203/205 doubler is stripped on the bolt holes that connect to the cross member. Got any good ideas on how to fix or repair???
Since I have the same plate, i will check the sizes and see if i have the stuff to helicoil it.Never used one. I have good support for it. They were already stripping when I got it from the previous owner, I didn't purchase it from ORD, bought used. The bolts are fairly long so not knowing anything about helicoils I wasn't sure on installation of them.
I am planning on ordering gasket kits for both the 205 and 203 but wanted a fix for the plate before I went through all the work of pulling the doubler and putting all the new gaskets and seals in and re-assembling.
Cool. Two hands better than one. When is this going down?Cool drag it over pull the Tcases replace gaskets, seals, blah blah, helicoils, all set.
stock adaptor yes . . .If I am thinking right can you drill out to next larger size, use longer bolts and put nuts on topside?
