Questions About Factory Options
BlazerGuy
3/4 ton status
abcde
On the sticker that's on the fender, it says that it is a Sequoia Special. What's a Sequoia Special? Also it says that I have a locking diff. What kind of "locker" do I have, I thinks its the Gov-Loc, right? Thanks for your advice.
http://www.blazer.coloradok5.com is now under construction
YEEEE HAWWWW
Mine says I have a locker too, but I think its really a limited slip. They just called it that for some reason. I may be wrong...
Brian
No clue about the sequoia package, but the locker is most likely a eaton limited slip made for GM, unless it is a military truck which is then a Lockight LOCKER.
"Got stuck once, hung up on top of a Jeep!"
Only time I've heard of a "Sequoia Edition" was a special edition of the Toyota ForeRunner. Don't know if it's just a sticker someone else thought was cool?
Brian
89KBlazer
gm has an additive that must be used when fluid is changed. regular gear oil is ok, but the additve MUST be used.
your right. I don't understand the jeep thing!
The factory option limited slip diff was called the "Gov-Lok" by GM, or listed as a locking differential on the option sheet. I really wouldn't consider it a true locker as it definitely not in the same class as the Detroit Locker or Lock-Rite. The Gov-Lok has a reputation for failing and being rather ineffective, though some people have had good luck with them.
The factory owner's manual states that a limited slip additive should be added to the standard 80w-90 gear oil. The additive contains a friction modifier that is supposed to make the clutches operate smoother and more effectively.
Concerning the Lock-Rite, I have never heard of them being used in military trucks. The mid-80's GM military pickups had a Detroit Locker installed in the rear 14-bolt axle, and I believe the military Blazers (CUCV's) used the standard Gov-Lok in the rear 12-bolt axle.
Your factory owner's manual is wrong, or my 77,78,and 79 factory owner's manual is wrong !
I think i have read on the Eaton web site that one of the main reasons GM asked them to design the Gov-lock
was to eliminate the need for friction modifier . My three list 80w-90, that meet a GM spec. no mention of
any additive.
care to explain ?
