ciffer
is there any differance between 700r4s in 4x4 vehicles and those in RWD vehicles.
find a 4x tryanny
the housing has the bosses for the 4x inspection cover, making it much more rigid & stronger...
the first one i was looking at is definitely not 4x4 but i think i found another one in my area that is a 88-92 4x4, low mileage and the guy is asking $200. i am going to try to pick it up tomorrow. i figure at that price, even if the K10 never needs it, it is worth buying just for a spare.
slightly different subject, what is the inspection cover?
are there any tricks to removing the transmission or is it just a matter of unbolting it and taking it out? does the transfer case have to be removed with the transmission?
Yes, lefty loosey righty tighty. Just remember the case is aluminum. Flare nut wrenches are your friend here.can the cooler line bungs be safely removed? the bungs on the new transmission have a little bit of grime in them, i would like to clean that out before installing.
Where is the 7th bolt? 700's, 4l60's, and 4l60e's only have 6.Doesn't have to if you have a proper tranny jack, but it will probably be easier if you do...
removal is pretty straightforward.
remove driveshafts, speedo cable, wire connectors, shift linkage (tranny & t-case), vent tube, fluid lines to cooler, inspection cover, torque rods & remove torque converter to flexplate bolts
drop crossmember & t-case
remove 7 bolts holding tranny to engine, drop tranny
installation is the opposite
