I just did this swap. Here is what you need:
205 from a th-350 (27 spline)
factory 350-to-205 adapter
shifter (I went to a twin stick)
27 spline coupler sleeve
flat style crossmember and mounts
Spacer Kit http://www.transmissionpartsusa.com/Quick_Swap_switch_kit_700_to_350_4x4_p/609-00007q35a.html about $55
I had to have my front shaft shortened and a new rear shaft made.
You will also have to cut about 3/8" off of your output shaft. (go slow don't get it too hot. It is hardened and you don't want to take out the temper)
-I think that's it.
One tip I can give you is make new studs. Don't use the ones with the kit. They were too short for me. I made new ones about an inch longer and it made it alot easier.
