Quick AN fitting ???
Smokinthehippies
3/4 ton status
Millard, NE
Having never used AN anything before, to hook up a fitting do I need to Teflon tape it or any thing else to make sure I get no leaks?
Going from the fitting on my fuel cell to a normal hose Barb
If it has one, yes on the pipe thread side. For the nut+flare+fitting side, no.
no teflon.. NPI is generally the only place you'll use a thread sealant on a fitting...
That fitting WILL NOT use any sealant of any kind. The end that attaches to the fuel cell is the AN 37* flare and it seals on the flare NOT the threads.
