Quick D60 Question
THISISWEIRD
WV
If I wanted to swap in a D60 in place of my 10 bolt front, is it just a bolt in swap? Or do I need to do some major work?
The perches will be the same width, but you will need new U-bolts and spring plates. You may have issues with driveshaft length and U-joint size depending on your current setup and need new rims unless your 10 bolt is an 8 lug.
dpending on what year axle you have now the brake lines may have different ends where they bolt to the calipers.
the few things that are different are simple, go for it.
